Plumbing Q Shower switch | Ford Explorer Forums - Serious Explorations
you know that switch on the faucet in the shower you pull to switch it from the tub fill to the shower?
It is bad or harmful to always leave it in the shower position ?
I push mine down to try and drain the water out. I despise that cold blast of water that shoots out when you first pull it up.
But, that means I also get the water temp set before I switch to shower mode.
Indeed, the corrosion issue is the only possible problem it could create.
FWIW, my three year old Delta tub faucet automatically clicks open when you shut the water off, allowing it to drain. I guess I just assumed that they all did that....
-Joe
I despise that cold blast of water that shoots out when you first pull it up.QUOTE]
Haha yah that really sucks. I always drain it, but sometimes the roommate leaves it engaged and gives me quite the surprise of cold water!! :rant:
