plz help no 4x4 | Ford Explorer - Ford Ranger Forums - Serious Explorations
plz help no 4x4
dayton ky
1994 xlt
1994 explorer 4x4 not working. 4hi button does nothing no lights,sounds nothing. 4low light by button comes on 4x4 dash light comes on,escm clicks.and i put it in 4low and trans in gear and couldnt rotate front driveshaft so i assume tranfer case is engaging. is it the junk auto hubs?
BrianDye
I'll have another...
Monroe, MI
2006 XLT
The automatic front hubs are probly the first most common thing done to the 1st gens (swapping fr manual hubs such as WARN)
dayton ky
1994 xlt
does it sound like the hubs are the problem to you? i just dont want to by the manual hub conversion and still not work. anything else i should check before i buy the kit?
BrianDye
Monroe, MI
2006 XLT
Im honestly not the guy to ask, I would say the hubs DO sound like the problem, but im not sure why the 4x4 lights arent coming on...
Can you hear it engage when you press the button? (Are you also in Neutral, with the brake pedal depressed?)
dayton ky
1994 xlt
the lights do come on when i hit the 4low button just not when i hit 4hi. i do hear something under there and i am in neutral....
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
If no Lights then it's not the Hubs.
Sounds like the Shifter Motor is not going into 4Wheel High.
dayton ky
1994 xlt
the lights do come on when i hit the 4x4 button. little light by the button comes on and 4x4 light on dash comes on.. but front tires wont grab...... the low range button is the one that does nothing,lights,sounds,etc..........
