PML A4LD Deep Transmission Pan NEW | Ford Explorer Forums - Serious Explorations
This is for a brand new never installed PML cast aluminum deep transmission pan for a A4LD. This is the info listed where I bought it. I am asking $210.00 Shipped anywhere in the lower 48. I paid $270.00 for the pan. The pan is painted black with engine enamel and all the mounting hardware and instructions are included. If you are interested I will pm you my pay pal info. Have a great night. This heavy duty, extra capacity Ranger and Explorer Ford transmission pan fits 2WD and 4WD vehicles with the 4R55E, 5R55E, 4R44E, and A4LD transmissions. These 4 and 5 speed transmissions are found in primarily in 1985 to 2001 Ford Rangers and Explorers but can also be in several models and years:
Ford Aerostar, 1986-1997 with 2.8, 3.0, and 4.0 engines (the 1986 model was introduced in 1985)
Ford Bronco II, 1985-1990 with 2.8 and 2.9 engines usually have front cross member interference
Ford Explorer, 1991-1994 with 4.0 engine
Ford Explorer 1995 - 2004 usually have exhaust interference with a larger transmission pan or have a 5R55W pan which requires a fill/level check on the pan)
1990-1993 Ford Mustang with 2.3 engine (may have AOD transmission and clearance issues)
Ford Mountaineer, 1998-2001 with 4.0 engine
Ford Ranger, 1989 - 1997 with 2.3 (4 cylinder), 2.5 (4 cylinder), 2.9, 3.0, and 4.0 engines
Ford Ranger, 1998 and newer with 2.3 (4 cylinder) and 2.5 (4 cylinder) — 4.0 and 3.0 engines usually have exhaust interference with a larger transmission pan
Ford Thunderbird, 1987-1988, with 2.3 engine
Mazda Navajo 1991-1994
Mazda Pick-Up 1994-1998
You've got PM.
