po303,po316? | Ford Explorer - Ford Ranger Forums - Serious Explorations
po303,po316?
cjben
Illinois
2004 ford explorer
2004 explorer. showing codes po 303 and po316. no misfiring and is running good. Should I replace the coil on that cylinder or wait and see if the code repeats? I erased them but could only drive it for a couple minutes. codes haven't came back yet.
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
Wait and see if it happens again, if it does, move the coil to another cylinder and see if the mis follows it.
cjben
Illinois
2004 ford explorer
well,it is a legit code. It comes back every time I reset it now. how hard to change coils? does the fuel pressure need to be relieved and the fuel rail removed? looks like it to me,just want to know before I create extra work for myself
Number4
Woodstock, GA
Assuming you have the V8 here, the coils are held in place by a screw into the intake. The coil boot is flexible, so they'll flex out of the way of the fuel rail. Easy to do, just don't over torque the coils back down, or you could strip the brass insert in the intake.
cjben
Illinois
2004 ford explorer
well damn. not good news. all the spark plug holes on that side of the engine have coolant in them. I blew them out,dried everything the best I could,switched coils,codes still come back. So now I need a new coil and probably an intake gasket. Will have to go to the shop for the gasket. This just got expensive :(
Number4
Woodstock, GA
Same code? Or for the cylinder you moved the coil #3 to?
Number4
Woodstock, GA
Oh, well that was easy then.
cjben
Illinois
2004 ford explorer
Yeah but the intake and gasket won't be so cheap or easy. Lol
