burnstony
- December 30, 2009
- Bedford, IN
- 98 Ford Explorer Sport 4x
I just purchased this explorer a couple months ago from my brother and had to replace the timing chains to get it on the road. Lil did I know I was going to use 200+ a week in gas!
The only modifications done to the vehicle is upgrade the tires from the factory to Firestone Destination M/T - P265 70r 16s. I did adjust the torsion bar in order to allow my tires to fit and my front end does sit a lil higher than stock. But even before the upgrade my milage was about the same. I am at a loss of words and don't have any idea how to fix it.
I ran an OBDII Test on it and it's response is as follows...
OBDII SCAN
(IF scan needs to be run with vehicle on for better result please let me know)
Error Code PO420 - Catalyst System Efficiency Below Threshold
I/M Status
Missfire OKq
Fuel System OK
Comp Com OK
Catalyst OK
Heated Cat N/A
Evap System OK
2nd Air Sys N/A
A/C N/A
02 Sensor OK
02S Heater OK
EGR System OK
Freeze Frame Data:
Fuel System 1: Closed Loop
Fuel System 2: N/A
Load Value: 49.9%
Coolant Temp: 188 Degrees F
STFT-Bank 1: -1.5%
STFT-Bank 2: -3.1%
Engine RPM: 1795 RPM
Vehicle Speed: 20 MPH
Live Data:
Coolant temp 188 Degrees F
STFT-Bank 1: -99.8%
LTFT-Bank 1: -99.8%
STFT-Bank 2: -99.8%
LTFT-Bank 1: -99.8%
Engine RPM: 0RPM
Vehicle Speed: 0MPH
Ingnition advance: 0.0 deg
Intake Air Temp: 78 deg F.
MAF Air flow rate: 0.0 lb/min
Throttle Possition: 18.7%
Bank 1- Sensor 1: 02S Output 0.000V
Bank 1- Sensor 1: STFT - 99.8%
Bank 1- Sensor 2: 02S Output 0.000V
Bank 1- Sensor 2: STFT - 99.8%
Bank 2- Sensor 1: 02S Output 0.000V
Bank 2- Sensor 1: STFT - 99.8%
Bank 2- Sensor 2: 02S Output 0.000V
Bank 2- Sensor 2: STFT - 99.8%
Vehicle Info:
This is the information I have obtained. Please if anyone can help let me know. I get between 8.5MPG - 10MPG.....And thats just insane!
Anyone with advice please post back. I am about to sell the truck do to the
OBDII SCAN
Trouble Codes:Error Code PO420 - Catalyst System Efficiency Below Threshold
I/M Status
Missfire OKq
Fuel System OK
Comp Com OK
Catalyst OK
Heated Cat N/A
Evap System OK
2nd Air Sys N/A
A/C N/A
02 Sensor OK
02S Heater OK
EGR System OK
Freeze Frame Data:
Fuel System 2: N/A
Load Value: 49.9%
STFT-Bank 1: -1.5%
STFT-Bank 2: -3.1%
Live Data:
STFT-Bank 1: -99.8%
LTFT-Bank 1: -99.8%
STFT-Bank 2: -99.8%
LTFT-Bank 1: -99.8%
Engine RPM: 0RPM
Vehicle Speed: 0MPH
Vehicle Info:
- OBD2 Protocal: SEA PWM
