Poor Handling When Windy
cfoellmer
Chicago, IL
2020 Ford Explorer Limite
We have noticed that the handling of the 2020 Explorer is not ideal. It feels like driving on ice. It is especially bad when it is windy. The car is all over and the slightest movement of the steering wheel feels like you're swaying back and forth. Has anyone noticed this?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Considering all the 6th gen Explorer owners here, I believe this is the first time this has been mentioned. Have you mentioned this to your dealer?
Gary Crist
Location
TEXAS a whole different country $1K Green AWD
TEXAS
1997 AWD V8
Callsign
KI6FG
Have you done a 4 wheel alignment yet? Funky toe settings that are
"with-in specs" will do what you are explaining. Also are the air
pressures on the "low" side of the recommended specs?
EXFAN
San Diego, CA
2021 LTD 4WD
2009, XLT
Agreed as quoted, have the alignment checked. Front toe and caster can cause "wander" and rear toe settings can cause "squirming" especially at higher speeds. BTW, are your wheels and tires OEM? Aftermarket wheels, tires and "plus sizing" can cause stability problems.
peterk9
Staff member
Moderator
Callsign
VE3
Have you checked the tire pressures to make sure they were reduced to the proper PSI from the shipping setup?
I bleed Ford Blue
North Olmsted
2021 Explorer ST
Also check to make sure the front sway bar is there and actually attached. A missing or not attached sway bar will cause excessive body lean while turning and during high wind conditions.
By not attached I mean a missing end link or a broken one. If just one side is broken or missing it will render the entire sway bar useless.
BJB94
Pa
2021 explorer XLT
Ford has anti sway electronics working in the background. This is the weird feeling you are getting. I wish you could turn it off because I think it does more harm than good.
