1banger
New, "06/01/2011 Build date, Limited has popping noise when turning
steering wheel. Only one pop is heard.
Easy to duplicate, as it happens every time I turn the wheel left or right
to make a turn. In both forward and reverse. Sounds like a steering
linkage issue, or possible front strut loose as it happens when you make a slow
speed turn which unloads the front suspension on the side you are turning
towards. Don't notice it at normal road driving speeds.
Anyone else have or had this?
I am going to the dealer to have a leaking (moisture in the lens), LED turn signal module replaced in the right side door mirror on Monday and will demonstrate for them.
Just a quick review. Overall, happy with the way it drives and rides. Very
quiet inside. Did a lot of test drives and researched forums on Audi, Lexus,
VW, 4Runner, Pilot. When it was all said and done the LTD won with more standard features and quiet ride, for the price.
Was well aware of issues with MFT, and a few other things, rgt A Pillar and such. So far only very slight pillar buzz at highway speeds and 15mph or so crosswind. Can only hear if everything is turned off inside. Will monitor to see if it gets worse. MFT rebooted 2 times so far. It does take about 15 to 20 seconds to fully boot to the point where voice commands or operable. No problems so far with other issues mentioned here and in know TSB's.
Currently 600 miles.
