xbljackalblood
- May 1, 2011
- Telford, PA
- 98 Eddie Bauer V8
Car in question: 98 5.0 AWD with 3.73LS and 150k.
Noise sounds like a bearing issue in the front end. Occurs mostly at low speeds (0-20mph); both accelerating (winding up noise) and decelerating (winding down noise). Does not occur in neutral/park.
Occurs sometimes after a shift in the trans; basically low whine to high whine, shift, low whine to high whine, shift, etc.
Noise mostly/completely goes away when maintaining a constant speed. Disappears completely when all four wheels are off the ground and spinning at all speeds.
Fluids in the trans, transfer case, and rear diff were changed with fully synthetic Amsoil less than 100 miles ago. Front diff is full, haven't had time to change. Noise did not change.
Transfer case is not binding as all four wheels spin when off the ground.
Both front wheel bearings are smooth with no play. Suspension is also tight with no play.
Tires were replaced with 265/70/16 General Grabber At2s and the truck was aligned to spec. Noise did not change.
The tires and fluids were changed for maintenance reasons only, not to fix the noise. Again, there is no noise at all when up on a lift so this has me stumped. Any questions, just ask. I have access to a lift if that helps with any tests or ideas you guys might have. Thanks.
