97exploder19
- April 20, 2010
- 99 Limited 5.0
99 5.0 Limited with EATC.
Problem Ive had since buying the truck is weak heat when its under 50 outside. The truck has never had good heat unless I play around with the temp settings (going back and fourth from cold to hot) and even then, it doesnt last long. For instance, I had hot heat when I was idling while waiting for someone and playing around with the temp. Woke up the next morning and the same settings produced weak heat but that could be due to driving around and the roads moving the blend door.
The truck is getting up to operating temperature (verified with OBD2 bluetooth dongle and Torque app). Doesn't overheat in the summer months.
What Ive replaced or done over the last year or so:
New Ford blend door actuator (old one still worked after removing and testing)
New Ford heater control valve (old one was actually faulty and not moving inside, despite the vacuum actuator moving outside the valve)
Reverse flushed heater core with garden hose. Not really dirty at all and plenty of flow from one side to another.
New Motorcraft thermostat (installed in 2013 by myself).
Verified flow to the heater core after bypassing heater control valve and replacing small section of hose with clear hose.
This all leads me to the blend door. I can get cold air coming out of it when I turn the temp to 60. If I move it around 75, ill get warm air, moving it to 90 and there isn't much of a change in temperature.
Does this sound like a blend door problem? I really don't know what else could be the problem now.
