AKexplorer21
- November 26, 2013
- Anchorage, Alaska
- 1996 Ford Explorer
I have a 1996 manual transmission Explorer, 4.0 L with almost 150,000 miles. I love having a stick shift explorer, but I've been experiencing engine problems since almost the time I bought it a year ago.
I thought I resolved this issue a while ago, after I took my car for a rough idle. I had all the upper intake manifold gaskets and valve covers replaced, as well as swapping out a cracked head gasket for a new one. All plugs and wires were replaced too, as well as the fuel filter.
This repair held up for a while, but a couple weeks ago I noticed that my explorer was idling rough again. The rpm's were stable at just about 1K unlike last time, but the engine shakes hard enough to rock the whole car. Shortly after that, my check engine light started blinking under hard acceleration. I've also heard the infamous "tic tic tic" of a noisy lifter, but this has happened sporadically over the past few months and may be unrelated.
I didn't have a code scanner, but I was positive that one or more of the cylinders must be misfiring. I was worried that the head gasket had cracked again. I took it into my mechanic to find out that the catalytic converters were incredibly clogged, and one of them was over 800 degrees when I pulled it in. Hoping this was a result of my previous problem finally manifesting, I had my cats removed, scraped, and replaced. (No emissions testing here)
The engine ran better, but still not near 100%. My mechanic told me that it was hard to tell without pulling the heads, but he thought it was likely a crack in my cylinder head itself. After putting about 1500 into this vehicle already, this was the last thing I wanted to hear.
I'm wondering where my next step from here is. I could buy a new or refurbished cylinder head, but that seems risky without knowing that it's the problem for sure. Would it be more economical if I simply found another motor out of a salvage explorer or ranger and swapped it out? If there's a good oil additive that would work well as a stopgap for now it would be nice to know. I love this explorer, but I'm starting to think about cutting my losses and selling it.
