MistahYebba
- June 29, 2015
- Clearwater, Florida
- 2005 Ford Explorer XLT
Just like everything else... you gotta start somewhere to learn the ropes, right?!
Well, I just bought my first car. It's a '92 Ford Explorer Sport (2 door, 4.0L v6). I believe it's a RWD? (Correct me or confirm this please)
There's a few problems with it so far and I want to learn how to correct them myself. So I'm going to list them.
When I first got in to start driving it I reset the trip odometer. My first 50 miles in, it started smoking. I drove home right around the corner and shut it off. There was a handful of puddles coming from the bottom.
You had the standard A/C condensation puddle, some sort of brownish/slightly clearish liquid dripping relatively slowly (oil?), a green liquid (antifreeze), and then one more drip (transmission fluid).
Popping the hood was like standing in front of the sun. It was very hot. I decided to let it cool over night.
So, taking it 1 leak at a time, I started the next morning by turning on the car and seeing if it leaks..
Nothing really. There was A/C condensation again since the AC was on... so.. here are the 3 leaks from the day before:
The oil leak... was this just oil on the undercarriage being washed off by the overheating fluids?
The antifreeze leak... there's a radiator coolant overflow tank (reservoir)... if it's so freaking hot, is it normal for radiator coolant to leak out?
The transmission fluid leak... this was the only concerning one... I knew I must have lost a lot of transmission fluid.
So, I started with the transmission fluid leak. I took off the transmission pan and every screw on that pan was very loose. So it's no wonder it was leaking! Furthermore, the gasket around the pan is the factory-grade cardboard. It was in poor condition and basically just bound to leak.
So I replaced the transmission pan gasket and filter... put everything back on and that would have "hopefully" fixed the transmission leak.
The next question was... why was it overheating at all? There was plenty of coolant.. the temperature gauge was on "normal" the whole time... (must be broken then?)... the heat works fine, so I presume the water pump works (maybe that has no correlation)... So why else could it have overheated?
My only guess was a faulty thermostat.. so I went ahead and replaced that too.
After replacing that... the truck runs fine. I drove probably 40 miles total yesterday... and that raised more questions...
It stalled a handful of times but only when I was at a complete stop somewhere. This wasn't every time I came to a complete stop, but about 5-6 times during my entire journey. This was frustrating as I wasn't sure why.
When I got to my main destination (the beach) and shut off the car, I could hear some concerning "bubbling". I popped the hood and realized it was the coolant/wiper fluid reservoir bubbling. Why does this happen? (I have read that it can be a bad radiator cap, blown headgasket, air in the coolant system, etc... but no solid answer.)
When I put it in to gear, i.e. Drive/Reverse, the car knocks a little bit. Nothing too serious, but why does it knock? Could this constant knocking every time I switch gears be the reason that the original transmission pan bolts were so loose?
If those bolts got loose enough to make me lose so much transmission fluid while I was driving, could that be the reason for overheating? Would you overheat from losing transmission fluid??
So...
lots of questions but I'm open to discussion so please do join! I'm going to check the "Check Engine" light codes today by doing the EEC Self Test or whatever it's called using a paper clip and following some instructions found online. If I get any avid helpers on this post then I'll keep ya'll updated!
Thank you!
So...
Thank you!
