POssible Spindle nut fix? | Ford Explorer Forums - Serious Explorations
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
OKay guys I found this online. Anybody know if these Ford Spindle nuts will fit our D35 TTB axles? I assume they will since the D-35 uses the same spindle nut and spanner wrench as a D44....This would be a fix for the spindle nut working itself loose with large tires.
http://www.4x4wire.com/jeep/tech/axle/d44nut01/
I haven't seen that mod before, but as you said the D-35 and D-44 use the same setups. Seems like it could work.
