Emsant50
- August 9, 2017
- Location
- Connecticut
- STAFFORD SPRINGS, CT
- 1994 Explorer XLT 5 Speed
So I replaced the M5OD transmission in my 94 xlt. Did the master and slave as well. Did it twice actually because I'm an idiot and didn't r+r the slave the first time. Drove it to work this morning and for the first few miles it was fine. Then the throttle response got bad. Low power. Pedal to the firewall and no change. So I took it easy to work and it would randomly pin me back and start running normally. When it did, as long as I didn't let off the pedal it would stay. Otherwise it ran like garbage. Didn't have enough power to climb hills. I did start to smell gas after a while. I know I messed with the o2 sensor harness and unplugged two spark plug wires to get at the top bolts out of the tranny. I reconnected all of it after but I wonder of that affected it. If anyone has had a similar issue and has any guiding points id love to hear them. Thanks.
