Power antenna to fixed? | Ford Explorer - Ford Ranger Forums - Serious Explorations
nvrlate
Olathe, KS
95 XLT
Is it an easy swap to go from a power antenna to a fixed antenna?
Thanks,
Dave
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
I believe you have to pull the fender well out to access the antenna. Do you have the premium system? If so you will have to route the antenna lead through the kick panel & behind the glove box.
Mine quit almost 4 years ago but I never repaced it because I never listen to the radio. I have a CD in at all times.
The radio stations in Knasas City suck to say the least. Between worthless trafic reports, commerecials & the stupid blathering DJ's you get 2-3 songs in a half hour if you are lucky.
05dink05
MARYLAND
99 XLT - 97 EB
I know this thread is kinda old but since when I was searching I couldn't find a definitive answer and now since I just tried this I thought I would share my results. Survey says.... Yes, yes you can. I took a power antenna off a 97 Eddie Bauer and replaced it with a fixed antenna off a 99 XLT. The antenna cables were both the same size so the cable from the power fit into the fixed antenna.
