power antenna | Ford Explorer - Ford Ranger Forums - Serious Explorations
power antenna
JRM1290
Does anyone know where the hot lead of the power antenna is for a 1996 Explorer Sport?
The answer is that it is somehwere in the rear amp area. However, after much stress and fiddling (both mine and audio shop) we have not found it. Here's a tip. Find the antenna leads (under passenger dash) It should be two wires covered by a sheath. This is the - and + for the motor. Strip a 1/4 inch off both wires. Use a 9volt battery to raise the antenna. I was going to add a switch but found that the antenna is quite durable, even in the heavy rag washes. Good luck.
96' Eddie Bauer v8/awd
