Power Running Boards | Ford Explorer Forums - Serious Explorations
Pedalpower
Channahon, IL
01 ST, 06 LTD
I am on my third set of power running boards for my 06 Mountaineer. Does anyone have an easy way to replace the motors or a cheaper replacement than 1200 for each new board?
Thanks
If/when mine ever go out, I'll be watching for a set of fixed boards at a salvage yard.
I agree- those boards are the biggest pieces of Chevy that Ford ever stuck on a vehicle. Go fixed...
here how i fixed my running boards now I have no problems!
http://explorerforum.com/forums/showthread.php?t=291978
Front two nuts and one bolt
Rear two nuts and one bolt
unplug wiring
off truck
lay something soft down so no scratches
plastic sheild screws
motor cover screws
pull off motor cover
spin shaft untill it stops, wedge bolt will be accessible
remove wedge bolt
pop out wedge from back side
wedge
this is motor shaft, note black square will make mark on wedge
note mark on wedge for reintallation
spray lubricant on all moving parts
step on board and work up and down spraying lubricant in all joints untill moving freely
spray lubricant in transmission
spray electricial cleaner inside motor cover
spray electricial cleaner on shaft
inspect that the brushes are still good
apply small amount of grease to back bearing in motor cover, use something plastic to apply grease.
work bearing so it moves freely
insert motor cover, you might have to wiggle it back and forth
motor cover screwed in place
insert wegde in place
flip board over and insert wedge screw and tighten down
install plastic sheild screws
bring board back over to truck and plug in electric wiring and test board. reinstall all four nuts and two bolts securing board back to truck
deployed
board retracted, your all done saving 1600.00 bucks
I also wish they used the "Out" setting differently.
When you set it to "Out" they stay down, but as soon as you start moving, they go back to Auto-mode. I understand that this is to protect them and improve aerodynamics.
But a better option would be to have the "out" setting move the boards down, bring them up when you drive, but put them back down when you put in park/shut off engine. That way, they aren't going up and down every time you need to get something out of the truck in the garage. I would leave it in that mode all the time if it were available.
Use Deep Creep Spray(same as SeaFoam but in a spray). I tried different lubricants and nothing worked until I used Deep Creep last year and they have worked like new since-no problems-and we had alot of ice and snow last year. I should re-apply again to keep them working! :)
that's actually not a bad idea I'm sure I could wire them in that way. Someday when I lift the **** out of my 01 sport I'm going to get power retractable running boards for it and I'm going to wire it up so that when I shift into Park they come down unless I end up swapping in a stick shift by then. Then I'll probably wire it so that they come down when the e-brake is set or a door is opened.
Sorry to wake up a dead thread
