Power Seat/Power Pedals Dead | Ford Explorer Forums - Serious Explorations
hisdhome
2002 Eddie Bauer
my driver seat power pedals and power seat are not responding. Green light on memory switch also not lit up anymore. Mechanic said it was the motor assembly on the seat, but that does not align with the info on the web. It seems more likely the memory module. Checked all fuses and they are fine.
Any help is appreciated. Thanks.
Welcome to the forum
I moved your thread to the 2002-2005 explorer sub forum.
Check the wires in the rubber boot between the door and the body. I had something similar happen where all the electric motors; seat and pedals worked, but I wasn't able to program the memory. It ended up being two cut wires in that rubber boot and a third ones was stripping itself clean as well.
hisdhome, here is a great link with pics for checking for broken wires in boot between door and the body: http://www.explorerforum.com/forums//showthread.php?t=270081
Post #3 in this link has great instructions for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=271333
Good luck.
did you solve your problem?
