power steering pump whine | Ford Explorer - Ford Ranger Forums - Serious Explorations
freak
2000 XLS 5spd
I'm looking at buying a 98 4x4 manual Ranger that is said to have a whine from the power steering pump. (I haven't went to see the truck yet). Any time I've heard a whine it was low fluid but adding a bit fixed it.
1. Assuming this truck is full of fluid and still whines is the pump likely bad?
2. If I were to replace the pump would it get ruined again quickly because of debris in the oil from the bad pump?
Whityford
2000 XLS OHV 5sp 4x4
a whining power steering pump isn't all that bad. Mine has been whining ever since i bought the truck and i have never had an issue with it. That said though, you should defiantly change the fluid as that always helps.
Accarguy
Chicago, IL
2000 Explorer 5.0 AWD
Sounds like it is a bad pump.
If you are worried about the fluid, you can flush the power steering fluid which should be done if the fluid is bad.
Mike65
Location
In my garage working on one of our vehicles.
Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
Most all Ford p/s pump make some kind of whine noise.
rb142
Detroit, MI
2001 Ranger XLT 4X4
Make sure it has fluid AND that the air has been bled out. If it still is loud, then it probably does need a pump. If the old pump was bad, you definitely need to flush out the system because it is likely full of debris and that can damage the new pump.
freak
2000 XLS 5spd
How clean can you actually get it from doing a flush and is there a howto for it somewhere?
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
The 98 Ranger has the same pump as the 91-94 Explorers. They whine from the factory. It gets louder as time goes by and the fluid gets older. Remove the serpentine belt and the pump should be fine if there is little or no wiggle at the pulley. Flush out the system, and refill it with Mobile One ATF. Whine should go away and only come back at full steering wheel lock. This is the tried and true way to reduce the whine and has been used by numerous people on this forum. I have not had a pump fail from making noise, the one's I had go bad blew seals.
freak
2000 XLS 5spd
[MENTION=3817]BKennedy[/MENTION]... Very good info!!! Thank you!!!!
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
