bruce119
- June 14, 2010
- Holiday, Florida
- '93 Explorer
UPDATE PLEASE SEE POST #7 IN GREEN BELOW
Sorry it's a little long but I needed to tell details.
First I have 2 (that's TWO) 93 X's identical one is for parts. You guys helped me a lot when I got the latter one a year ago it has been running great thanks.
Now the problem the passenger window motor has stopped running. First time it happen the window was down motor would give a click but not start. It's not the nylon bushings I changed that last year. I took it apart took the motor out and it mysteriously started to work. So I put back together thinking maybe a solenoid or something like that stuck in the motor. It work for another week and did it again. Now I got the widow to go up and it wont reverse. I have power coming from the switch at the plug to the motor. It runs forward but wont run in reverse. But there is power coming from the switch. Now here is the strange thing I have another motor from the other X I know it is good I swap it same thing. OK so now I think switch BUT the old one did give power at the plug going to the motor. So I swap the switch SAME THING I am testing the plug in-between the switch and the motor yellow (up) & red (down) and I push the switch up I get power on the yellow zero on the red and when I push the switch down I get power on the red and zero on the yellow. What gives is there a micro stop switch or something at full open and full close but then I would think I wouldn't get power to the motor leads.
Sorry it was so long but I wanted to get the details to avoid a lot of simple questions.
Thanks guys
Bruce
Holiday, Florida
Thanks guys
Bruce
Holiday, Florida
