Power Window Problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Hawkeye999
Huntsville,AL
92 XLT
:usa: I have purchased a right rear door for my 91 because of collision damage. Inside of the door has a broken steel cable that works with the power window. I have changed motors and replaced parts in the motors with no problem. But I am not familiar with what the cable does. I think it is part of the regulator mechanism and the motor parts on the door I am replacing are not damaged. Both ends of the cable are simple to remove but I need to know what is involved with swapping window parts other than the motor. Are there any tricks I should knowe about and are there any adjustments I need to be aware of. Thanks
falls guy
St. Catherines, ON
'91 XLT
That is part of your regulator assembly. You'll have to change that too by the sounds of it. Just change the entire mechanism/motor and all. Easy. Remove inside trim, drill out rivets holdin in window. remove window. Two rivets on the bottom and I think two on the top, and the whole mechanism comes out the access hole in the door. Good luck.
Peace
