power window wiring problems | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
sam3
madison wi
1996 ford explorer
I have a 1996 explorer the power windows don't work unless I wiggle the wires in the drivers door jam
Ok, you will need to remove the bolt in the connector, then working the rubber boot off the jamb harness and into the kick panel, you will probably find a blue wire with a black stripe which has broken. I fixed this issue by adding a small length of wire into the harness, which did add a 2 splices into the line, but worked fine. Make sure the connections are tight. Soldering and heat tube are the best way.
