scrutton
- May 10, 2000
- Durham, NC
- 1996 Sport 4WD
I've discovered that pin 8 (memory) of the grey connector (8 pin connector) in my Dash has 0V on it. This is the pin that is supposed to be at battery voltage and is un-switched, so regardless of ignition switch it is supposed to be always on.
This is causing me problems hooking up a new headunit into it (the headunit won't function until it sees 12V+ on this pin). I've used an alligator clip to do a workaround to ensure the unit works (and it does).
So, my question is, has anyone else come across the memory wire having 0 volts going to it. Or, have I blown a fuse somewhere that is causing this? If so, what should I be looking for. I have checked the fuse near the battery, and also the fuses labelled for radio in the fuse panel near the drivers door.
I'm contemplating splicing into the harness to get round this problem, but I can't help think that there may be an underlying reason for this. Anyone know what fuses are in series with this wire?
Paul
Paul
