Pre '94 vs. Post '95 PS pump | Ford Explorer Forums - Serious Explorations
Yomie
Biloxi, MS
06 Toyota
I'm looking for pictures of the 91-94 PS pump.
I'm trying to see if the '94 and the 95+ Pump bolts in the same location on the motor. If any one has any experience or any knowledge please chime in
I already know the 91-94 pump has less pressure so it won't push the Rack and pinion. I'm not using it for my rack and pinion. I'm going with a steering box out of a early X or ranger and need a lower pressure pump to turn it. I know there are few that have used the stock pump with these steering boxes, but few have had problems blowing lines and so forth, i'm trying to eliminate the problem so there are no steering worries.
The last thing i want to happen is to be driving down the road at 55mph and have a steering line blow!
Hmm...ANyone?
Nevermind i found out that they are the exact same pumps, except for the Valve mechanism on the side, thus allowing the pre 95 to put out less pressure
I thought they were the same, bolting up...
the heads and block are pretty close in design between 94 and 95;
I just wasn't sure enough to say...now I know
