Prerunner/weekend toy Explorer | Page 12 | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
I have a thread up in modified 95-01 Explorers, but since mine is mainly off-road I figured it would be more suitable to have a thread in here.
What I am working with
97 2wd Explorer 4 door with 5.0L V-8
Front suspension: 14" Wheel travel
Modified LCA to accept a 1" uniball as the outer pivot then boxed in accordingly. Custom UCA with 7/8" heim as outter pivot and 3/4" heim on frame pivots. Fabtech lift spindle tapped out for the heim and drilled knuckle for a 7/8" on the outter tie rod as well. Fox twin tube bypass shocks as well as a 2.0 body air shock per side assist the stock torsions with spring rate. Fox hydraulic bump stop off of the UCA
Rear suspension: 18" wheel travel
62" race leaf springs by Deaver with custom 12" long shackles. 18x2.5 triple bypasses by Fox though the wheel wells.
Other:
Baker 8" front fenders with FIberwerx 8 " fiber glass rear panels. Front and rear bumpers with a 2" rollcage threaded throughout still in the making. Fullsize axle out back with 4.56 gears and a L/S. 35x12.50 BFG Baja TAs and some Pro comp rims to hit the ground running.
calling @danwaters dont keep us waiting ;):D
Ok it’s been a while since I’ve made an update here. The project was a little on pause due to building my dads sand car and followed by a lack of motivation lol.
Here’s an update…
Took the whole front end apart and motor/trans out.
Had a 331 SBF stroker built by TRE Performance in Santa Monica.
Used Holley EFI Terminator X for my fuel management and ECU.
I converted the trans to full manual VB, no longer comp controlled.
I had my buddy build some chromoly boxed upper arms cause I’ve folded 2 sets of tubular. Cut original arm mounts off and plated the frame with 1/8” chromoly up to where the a-Pilar tube on the cage strikes the frame. I build new upper arm tabs to accommodate for the 1” wider 1” longer arms.
I added a 3.0 bypass to replace the 2.5 and added a set of SAW 2.5 race hubs. Matched with a set of 14” Coleman rotors and some big 6 piston Aero9 Wilwoods, stopping would not be an issue.
I got everything finished up and started on the steering.
I dual sheered the new rack and rebuilt the steering shaft out of 3/4” chromoly and added a 1.5:1 quickener as I built the steering column.
I installed a Fiberwerx dash and cut in all my instruments and accessories.
Had the truck wired bumper to bumper with everything new and fresh.
I built my own center console and upholstered it after cutting in a few things.
After all was said and done I took the truck down to go get tuned. It put down 280/321 @6200 still building power. That’s twice what it had before!
A9B30321-A205-4DF4-95CD-E072D3172235.jpeg F9085512-F43D-4E2F-81F0-50ADC0089497.jpeg 68D64535-09AD-4E3B-8386-269C7E474318.jpeg C4F665C8-2A36-49D5-B225-45E5842D42C1.jpeg EDF37058-1C40-4BA9-81DE-BBB543E6A69E.jpeg 3B8B2013-331C-44A0-B96E-868BF04EF54F.jpeg 4CDB555F-6612-4924-B3D4-A8D865A3F749.jpeg 7FDC5CA3-17F0-438A-B14E-7D0301FAACA9.jpeg B8054B59-50CA-40C1-A88F-D5160A523825.jpeg 329F1DE1-53B1-404D-8CAE-15B486F3D3CC.jpeg 941C6B22-AEA7-41FF-85C3-1D24A6CD182D.jpeg E02EBA18-EB9E-44F1-B61D-6BC4560BDB39.jpeg A767DB0E-DFD8-4DD8-9D88-0CE06C594669.jpeg 2BE54F04-0196-4A0B-AB76-F6AE466CAB4E.jpeg 1698941F-8943-483A-8BD9-1C8DD0B14210.jpeg 618E2055-CC44-4DF9-B893-3EE3785673C6.jpeg 1181ED9F-848F-4FAC-A466-CD7CF33908A4.jpeg 0F08BC71-8D44-43C1-B3E4-1CCE54703172.jpeg 8662C5A6-C562-453A-B912-7245B3D2356E.jpeg C36608C6-5195-48D7-9965-F55F5F3E8616.jpeg
I added a few more things here and there…
2D762E72-23BB-49AE-AF7C-F3B7768AF06A.jpeg 99D3135B-E7FC-4459-AC68-45F49DFE5081.jpeg 72392A0A-A48E-4C3E-B904-CB27E5271488.jpeg B30A35BA-4400-4987-855B-6023FF69038B.jpeg 3B83BC89-8CE1-4BDE-AB52-C39A264C5F6E.jpeg 76EB228F-ED11-492C-9D6E-B491F9F582C5.jpeg 7A98B318-A001-4A71-98DC-096D63001FB7.jpeg 13B0D665-72D8-42E9-93FD-00FD8AE7DF5C.jpeg 3F0708FD-1FCC-43BB-8A3A-7624A8E2A55F.jpeg 66D015AF-28A5-4401-9E53-6B93A936FD19.jpeg 17F804D8-89BF-479A-968F-C826C2546921.jpeg A8C07AEA-0497-4D34-A441-7A1FC9EFAB05.jpeg DC89CF10-4E63-4752-ADBF-7D1D3B0F693C.jpeg 9ECF5EC1-BCC5-4271-BFDF-A38F51EEDA7D.jpeg D2DEAF5E-7443-49E6-AFF1-094E0CE82D40.jpeg 59AFECFE-4803-4F68-8767-FCC4BF0E49E1.jpeg F1734536-F62C-46C3-A871-3F97FEA0DCDC.jpeg 59F16550-323A-4A94-ACEF-C2B0E7BBDC14.jpeg E3948122-BEC5-4A8D-96D0-4462A806BFA7.jpeg 552D52CC-CDEE-4746-8449-449590B6AC91.jpeg
soooooo much want!!
Lack of motivation LMFAO!!!!!!!!!! looks like you played catch up.
good show! love how she just floats over the terrain
soooooo much want!!
I was working 60-70hr weeks and was just tired lol. One day my brother came over and helped me thread the needle on getting the new motor dropped in and that relit the fire! I was on it every night til 10pm working on in ontop of a gnarly work schedule. The hard work paid off! 🤙🏼
