Pressure? Temperature? Which one? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
BTR
MARIETTA, GA
2000 EXPLORER XLT 2WD
2000 Explorer XLT 2WD 4.0L SOHC JOB1 5-Speed Automatic 5R55E.
Can someone confirm the following? Thanks.
The EGR system uses a EGR Pressure Sensor... not a EGR Temperature Sensor, right?
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
koda2000
x
It uses a device called a DPFE (differential pressure feedback EGR). This device is known to burn out on Explorers, to the point it burns a hole in its housing.
BTR
MARIETTA, GA
Thank you. That's what I thought. I appreciate the confirmation!
BTR
MARIETTA, GA
Yep. I already ripped one of my silicone DPFE hoses... trying to get it to go onto the hard line nipple that comes off of the exhaust.
BTR
MARIETTA, GA
@DILLARD000 - Thanks. Question for you: Does the DPFE send a simple "ON" or "OFF" to the PCM... or does the DPFE send a "variable / varying" output signal to the PCM?
BTR
MARIETTA, GA
Yes, you're correct, my DPFE has 3 wires. Thus, it sends a variable signal to the PCM. Thanks. Very helpful.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Differential Pressure Feedback Exhaust
DPFE
Not diff press feedback element LOL
BTR
MARIETTA, GA
The challenging part of diagnosing this particular DANG emissions system is that the problem could be caused by any of 4 components. In order of operation, they are:
DPFE
PCM
EGR Valve Solenoid
EGR Valve
Not to mention any bad vacuum hoses and/or electrical wires and/or electrical connectors!!!!!!!!!!!!!!!!!!!
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
yes so its time for a full visual inspection before buying any parts
The EGR sample tubes can be checked out, no cracks, tears or leaks, are they still supple or hard and brittle?
The metal EGR line and the gasket at the intake manifold, there is usually a large O ring there can be a source of leaks
The EGR valve itself you can do a quick simple vacuum test with engine running if you put vacuum to EGR valve (with your mouth) the engine should stall out = working EGR valve
The DPFE can be ohm tested and visually inspected
The best place to start though is the code, do you have a trouble code?
BTR
MARIETTA, GA
The code is P0401.
BTR
MARIETTA, GA
RECOMMENDATION - Do not buy a DPFE made by Labwork. Yes, they are inexpensive ($10). However, mine lasted less than 30-days before it broke.
1998Exp
Seattle WA
98 Limited V8 AWD
Not sure what you can ohm-test there, but it can be tested completely if you have a half-decent scanner and a way to make some vacuum. Disconnect those little tubes, pull a bit of vacuum on the downstream one, and you should see the DPFE output increasing as the vacuum increases. Without a scanner, you can simply measure the voltage directly on the output wire - it should move smoothly from about 1V to 5V. However, if your ride still has one of those older style aluminum body DPFEs, it would be a waste of time to even test it, because those were defective from the get-go -- mine failed with less than 40,000 miles on the odometer.
