pro-m mass air flow question
youpey
ewing nj
04 Rx-8
I just got my new pro-m mass air flow sensor in today. I installed it, but did not notice any difference. Do i need to disconnect the battery to reset the ecm or will be automatic. or is this just the way it is
the only other mod i have is the mac cold air intake
i have a 2001 xlt 5.0
audiodude332001
Eau Claire,WI
2000 explorer 5.0
You need to disconnect the battery for 15 minutes to reset the ecu.
Redrig
Gettysburg,PA
1997 Mountaineer
You probably should let the engine idle until its warm before driving it also.
youpey
ewing nj
04 Rx-8
should i notice a big difference
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
Not a big difference. If you get a chip, exhaust, and throttle body then the Pro-M will complement those mods.
Think of your Pro-M as giving you more potential, with other mods, than you would have with a stock MAF.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Rhett is right.
The sequence of your installs wasn't very good. Mods build on each other, and the MAS on the 5.0 or a 95+ 6 isn't gonna do much with a mostly stock truck.
youpey
ewing nj
04 Rx-8
i am planning on getting the apten chip and a flowmaster exhaust pretty soon.
I wanted to add i saw in the apten site if you change the mass air flow the chip should be reprogrammed. that is 1 reason i got this first
