problem bleeding clutch master cylinder | Ford Explorer - Ford Ranger Forums - Serious Explorations
moose21
Vallejo,CA
'91 XL & 2000 eddie bauer
my slave cylinder went south so i changed it the clutch and the master cylinder i bench bled it before installing and i have tried everything to bleed it with no luck at all im getting half air and half fluid out of the line when bleeding it do you guys got any tips
Houston TX
2001 Sport
i had the same problem about 2 weeks ago
you just have to take the clutch master cylinder out but leave the lines connected and turn it upside down while you bleed it. You will have to pump the master cylinder by hand. and have a second person at the bleeder valve.
