Problem Bleeding Clutch Master | Ford Explorer Forums - Serious Explorations
ddave
Ft Lauderdale FL
94 XLT
I saw a video on how to bleed clutch master cylinder along with the pressure line. With the components out and hanging up as per the video, brake fluid is just running straight through out of the line. I thought with the quick connect, that's not supposed to happen. I should be able to presserize the line and install without it leaking. Do I need a new pressure hose? The master is new. Has anybody seen this before?
The quick connect fitting that connects to the slave cylinder is spring loaded. If the valve inside the fitting gets pushed into the fitting body too far then than spring jams up. Look at the fitting and see if the valve is flush with the end of the fitting, if it's not then you'll have to take a small pick or something and try and pop the valve loose.
Once again I. W., Foxracin, dead on. I'm not paying attention to the small stuff. Another easy fix. I'm back on the road again. It's nice to have the truck back. Thanks for the responces guys.
