icu400
- April 18, 2004
- Austin, TX
- '95 XLT
Ok, so here is the situation:
My amp and subs have been working fine recently, until today a series of events occurred:
1) I helped someone jump his car, and we used a red on red/black on black approach. The result was that his car works fine, and mine seems to still run normally.
2) I took my head unit out (sony 2004 model) in order to plug a cable into the aux input for my new ipod. The result was that the speakers work fine, as well as the aux ipod cable.
However, from some combination of these two events, my amp no longer turns on and the subs no longer work :/
So, to me, this means one of two things:
1) The cable that goes from the head unit to the amp to signal it to turn on is damaged.
2) The amp is receiving a signal to turn on, but not receiving power.
I notice a clicking sound when I start the car, from the amp. I took that to mean that the amp was receiving a signal from the in dash receiver. To test that, I completely disconnected the 4gauge power cable from the battery, and started the car again (with the amp receiving no power). The click still occurred. From that I am concluding that the problem is either with the amp, or with the power cable itself.
So, here is what i've looked at to see what could be wrong with the power cable. The connection with the battery seems to be secure. The fuse on the line near the battery appears intact, and the connection on both sides of it seems secure. The connection to the amp, for both ground and power, seem good. And finally, both fuses on the amp are intact as well.
This leaves me pretty stumped to be honest. The only problems i've had with the system (self install from 2004) was that sometimes corrosion on the battery would cause it to not start up right, or a few times the fuse in the engine compartment on the power cable would come loose. Nothing else ever gave me problems. The entire rest of the car stereo also works fine, the only problem is the amp.
So my question I guess is more of what should I check to fix this problem, and is it likely that the amp could have somehow broken without either of the fuses breaking in the process? Could it's power supply have just stopped working? I'm really not sure, so if anyone has any guesses on this, it would be greatly appreciated
Also, to note the specs of the system, it is a JBL amp from 2004, Infinity 10" subwoofers, and a middle line sony 2004 model head unit. I don't remember the model numbers offhand, but I could probably find them if it would be helpful information.
Thanks
Thanks
