iceman100
- November 20, 2007
- Massachusetts
- 92 XLT and 99 XLT
I have a 1999 Explorer with the 4.0L SOHC engine. The metal power steering line from the PS cooler to the steering rack rusted and was leaking. I cut off the line and used a socket to take off the fitting.
The problem is getting the new fitting back on. Is there some trick to get the fitting on. I attached the rubber hose to the PS cooler line, but I find it impossible to get the fitting thread started. I have tried from underneath, from the side, and from the top but there is just no room for a wrench and fingers anywhere. I have tried a crowfoot and still can not get enough access to get the threads started into the steering rack valve. The cooler mounting bolts are well rusted so i can not remove them with out destroying the cooler as noted in another post. Any help would be appreciated. Thanks.
