jamccor
- June 19, 2007
- Budd Lake, NJ
- 1993 Ford Explorer
Hi All
I have a 1993 Ford Explorer 6 cylinder, 2 door.
I have had this car going on 2 years as I got it used.
I am having a problem with the battery. At least once every month or two, my car will not start. The problem is Always the battery terminals,not the battery. I am always noticing corrosion on it. I have to either tighten down the terminal to the wires,or buy new terminals (I hope I am using the correct terminology as it is not the battery posts but the 2 cheap black and red alloy connectors I get at Walmart for 3 bucks!). Without fail, when the car decides not to start, it is never in my driveway,but at my job or at a store way out there. I have to lift the hood and move the negative or positive wires ever so slowly. When I notice the light under the hood go on I know the car will usually start. What is my problem? I am sure this is not normal used car behavior (but maybe normal for an Explorer?). Where can I buy good professional terminals and how do I keep corrosion off of my battery. This problem is getting to me. I appreciate all help and will even keep in mind replies that say to get rid of my exploder!!
Thanks
John from New Jersey
Thanks
