Bill MacLeod
- November 18, 2000
- Hamilton, Ontario
- 06 Ltd V-8
Finally got around to installing the Ford seperator plate/blow-off valve this past weekend attempting to eliminate a 2/3 shift flare. At the same time, replaced the EPC solenoid and steps 1,2,3,6 &7 of the Superior shift kit.
(could not do step 4 as the valve/plug could not be removed.)
On the test drive, the o/d started to flash after a couple of minutes. Also noticed that the RPM's were a couple hundred higher in 5th (overdrive). There was no converter lock-up.
Had the code pulled this morning. P0741 (TCC System Performance or Stuck Off)
Now I did remove the TCC solenoid on the weekend and sprayed some brake cleaner into it. Is it possible the I screwed the TCC solenoid and this is causing the problem.
Any help is greatly appreciated.
