NCSWolfpak
- March 25, 2011
- NC
- '11 Ltd.
Has anyone encountered any issues changing the wallpaper from the display options, and if so figured out a way to get around the issue? I have a jpeg image, size 120 KB that's 800x378. According to the manual, that should be spot on for what should work. However, when I select the image filename it says that it's not compatible. I tried 2 other images (same resolution, similar filesizes, all jpeg) and those got the same result. I'm assuming the USB stick is OK since it's letting me browse the FS to pick the file.
