TMBackstrom
- October 6, 2001
- Cheney, WA
- '94 Explorer XLT
1994 Explorer XLT
4.0L V-6
Automatic
90K miles
A couple days back my Check Engine light came on and my engine started randomly bucking. The codes I'm pulling out of the computer are 57, 58, and 85. According to the book that came with the diagnostic tool, it says:
57: Neutral Pressure Switch open circuit failure, or
Circuit failed in Neutral position, or
Octane adjust service pin installed.
58: Vane Air Temperature sensor signal volt too high, or
Crank fuel service pin in use, or
Idle Tracking Switch circuit failure
85: Canister Purge solenoid-circuit failure, or
Transaxle problem-3/4 shift solenoid circuit failure, or
Electronic Control Assembly status-adaptive "lean" limit reached in fuel control program
The Check Engine light is not solid most of the time. It comes on once the engine is warmed up, and usually turns off for about 30 seconds randomly every about 5 minutes.
Yesterday at a stop light I noticed "rotten eggs" smell coming up from the exhaust.
Any ideas? Any help will be gratefully appreciated. Thanks.
4.0L V-6
Automatic
90K miles
