- August 1, 2007
- Location
- Albemarle NC
- Albemarle NC
- '03 Eddie Bauer 4.6L 4x4
I purchase my 03 EB and it came with only one key. I ponied up and had a locksmith program a second key ($60). I then purchased two keyless entry fobs off Ebay. Programmed the first one ok but unable to do the second one, couldn't seem to get the system back into programming mode. I searched this forum for help but came across little that helped.
I did find elsewhere programming instructions that did work and let me program both fobs. I post it here to help anyone that might encounter similar problems. In my case closing the door and locking and unlocking seems to have been the key to get programming mode started.
Step-By-Step Key Fob Remote Programming Instructions
- Prepare Vehicle
CLOSE and UNLOCK vehicle using power door locks. - Enter Vehicle Programming Mode
INSERT key into Ignition and TURN from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm Programming Mode. - Program Remote
Within 20 seconds press any button on first keyless remote fob. Door locks will cycle to confirm programming.
(Repeat immediately for any additional remotes to be programmed.) - Exit Programming Mode
Turn ignition to OFF. Locks will again cycle to indicate end of programming mode. - Test Remotes
Test all remotes. Programming is now complete.
