Project Iceberg... | Ford Explorer - Ford Ranger Forums - Serious Explorations
Project Iceberg...
I picked up a minty 94 Mazda Navajo 4.0L auto 4x4. It is the LX package so pretty nice setup with the sunroof and PO had remote start installed. Plans for this rig is test mule for SAS kit I designed and made with my CNC. Truck is getting.
XJ Dana 30 4.88 with Detroit Truetrac
8.8 4.88 disc brake conversion and modified factory limited slip
Custom solid axle swap kit
Spring over rear with anti wrap axle perches
14 inch travel shock front and 12 inch rear
Custom winch bumper with Superwinch
Cut in rockers with step(rockers are rusting through on driver side)
Custom rear bumper with tire carrier like Mercs bumper
Heim steering
Flowmaster mufflar (sounds wimpy now)
First thing I did was get the spring over done in the rear, always helps keep me motivated to do the easy part first that way I can look at it and kinda get an idea what I have to look forward too. I made antiwrap perches with some 2.5 .250 square tube cut with my plasma and then drilled a center pin hole works great and doesn't cost more then your time and 6 bucks in steel. Started on the rear last week.
I normally just bolt every thing up and hold off welding until the front is up to make sure I get the pinion angle set.
Sitting on some 33s waiting for my return after I get the front set.
Diff cover showed...
Putting the CNC table to work...
Crossmember...
Driver side coil bucket...
Coil buckets bolted in...
Had to clearance the crossmember for the front driveshaft...
Fits like a glove!
Transmission mounting holes work great...
Weld or bolt on brackets for the Dana 30 to relocate the perches...
Arms built...
Steering and track bar built then it was testing time before I put the shocks on...
Shocks in and you can see where the track bar mount is...
Flexy pics
Next I will be doing some road testing and building armor. Also on the hunt for some 35s the 33s look weak on this monster.
Got some snow Yesterday after it started melting I took the truck down to play in the muddy gulch. Thing is a beast.
Winch showed up. Going to get to work on the bumper next week.
Took the truck on a 40 mile trip. Did great went straight down the road. Not a fan of the KM1s they are so loud.... When we got back took the truck back down to the gulch in the snow storm beat on it some more. Then heading back to house I hit a jump about 30 mph truck took it no problem. Bracket kit is working great.
Thanks!
Bumper almost done....
LED turn signals in....
Cut in slider/rocker...
Testing the new rocker...
Step on Pass side...
Driver side all done. No more ugly rust. I cut it out and made it beast mode... :D
I'll be more then happy to bring my Sport Trac out to you to be the first one for you to do a SAS on. I'll even bring the wheels/ tires, and other parts I already have stockpiled. You do great work from everything I see and read.
Ah dreams, they're nice. LOL
I'll be more then happy to bring my Sport Trac out to you to be the first one for you to do a SAS on. I'll even bring the wheels/ tires, and other parts I already have stockpiled. You do great work from everythig I see and read.
Bring it out!;) Thanks I never imagined my fetish for junky old 4x4s would work out like this. It is a ton of fun. :D
I am real pleased how this old truck turned out. I love it. I can't wait to wheel it.
One day I'll move back out west, hopefully sooner then later. Keep up the good work!!!
Finished up the bumper and got the winch wired up.
