Project TNT... | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Project TNT...
Project Torque 'N' Teal(factory paint color). 92 Ford Ranger 4.0L 5 speed(customers rig and he has been helping me). This will probably the first of many SAS swap Rangers. Already have two more lined up after this one. :biggrin: Let's get to the goodies.
Short bed regular cab. Wheeling friend 107 inch wheel base.
First order of business Explorer disc brake 8.8 axle swap, 4.56 gears, E locker, and Riddler cover...
Next we picked up some monster 63 inch( about 6 inches long then stock) Chevy 1500 leaf springs 40 bucks at the JY for a set. We decided we wanted mad flex.
Stang5lgt
Parker, CO
98 Mercury Mountaineer
We had to move the bed to make it easier to move the front spring hanger.
Brackets new location...
Now the back was sitting back on rear axle we move to the front. Here are some of the parts...
Stang5lgt
Parker, CO
Frame bracket fabbed up...
Pass side lower long arm mocked up...
Drivers side low loose fit. You can see even the stock drive shaft reaches...
This is so much easier then the Merc that there is a good chance it will road worthy by next week. Only major things I have left are upper arm for the front Y link, track bar, steering(it already has steering box just have to build the links and drill out for 5/8" bolts), and sway bars.
Stang5lgt
Parker, CO
More pics today.
Coil retainers done on the top...
Sitting on tires checking ride height. Going to try some different coils.
The rear is 4 inches lower right now but should be 3 inches higher after new shackles and the perches are changed to raised anti warp perches.
Stang5lgt
Parker, CO
Track bar...
Steering...
Pretty close to being done. Need a few parts for the brakes and some bolts. Figure out the shocks. But that stuff is all easy. Right now I have between 10-12 hours in the front. Has to be one the easiest SAS there is.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...Any pictures of the rear anti axle wrap perches?
..Looks like you already got some pretty tall blocks in the rear..What are you swapping in?
Tbars4
Moderator Emeritus
Elite In Memoriam
..I guess I'm not seeing what you are using for the anti axle wrap..:dunno:
..I am curious as I'm also running the chebby springs but with no overload on them..The Detroit wants to wrap the springs and I'm keeping an eye out on solutions as they come up..
..Great to see another Ranger gettin some lovin'..:biggthump
Stang5lgt
Parker, CO
The anti wrap perches are almost 3 inches longer then stock perches. So they help keep the leafs from wrapping. They work good on the Merc. Merc has 4.88s, Detroit, and being pushed by a 5.0 V8.
Tbars4
Moderator Emeritus
Elite In Memoriam
..Ok..Gotcha now..
..I thought you were doing a link set up..:confused:..Those look like a Currie product..Where did you find them/price/etc..?
Tbars4
Moderator Emeritus
Elite In Memoriam
..I got lucky with my guess..:D
...Currie also makes some killer shock tabs for the 8.8 ..;)
Stang5lgt
Parker, CO
You got lucky or maybe you saw the pic above with all the parts and a box that says Currie on it. ROFLMAO!!!! Subliminal message... :rolleyes:;)
I have a plasma cutter so I make my own shock tabs. Ballistic Fab makes some good ones too.
Tbars4
Moderator Emeritus
Elite In Memoriam
Stang5lgt
Parker, CO
I have used them before on a few axles not that impressed since about there are about 100 companies now making stronger versions of them. I build 8.8 axles for Jeeps at my shop the ones I use for the Wranglers are way stronger then those.
Tbars4
Moderator Emeritus
Elite In Memoriam
...That's ok...We won't hold it against you..:p:
Stang5lgt
Parker, CO
4.88s in today and everything hooked up minus shocks and sway bar. Austin(owner) was having fun driving around the parking lot until he blew a fuel line and lost all fuel pressure. But great day we got a ton done. Just little more work and she will be road worthy.
He was happier then a pig in mud. LOL
http://www.youtube.com/watch?v=k9uDxJadKCY
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
Way cool!!
What did you use (specs) for the RA's themselves? I see the bags of 3/4" joints for the TRE's, are the joints for the RA's 1" BF johnny's?
Have you ever used the Super 88 kit for the 8.8? I am tossing the idea of getting it.
