pro's or con's about 5.5" superlift on 94 sport | Ford Explorer Forums - Serious Explorations
lenschamp
CANADA
1994 SPORT 4x4
just wonderin if anyone has any comments of what i'm in for after i get 33's, 4:56's, 5.5superlift w/superunner steering kit and 3" body lift, what brakes first, should i prevent anything, thanx for your help
Thats going to look a little goofy. I was going to do the same but will probably remove my body lkift. First everything has to be in tip top condition for this. No slacking here. You are unlikely to find any better brakes for the X. I would however make sure they are in great shape, if not change them. No pad slapping either, check the rotors either cut them or replace. Same with the drums. You will Need extended brake lines. Pro comp has a decent set of braided stainless for like 100 bucks for both front lines and the center rear. Always if money permits opt for extended radius arms with a lift. They make a world of difference.
Unless you are doing all this work yourself this is going to cost you a fortune, keep that in mind.
