Protect your expensive investment 2 | Ford Explorer Forums - Serious Explorations
yogi_pahl
Athens Ga
I saw another post about a cool diy to hide you aftermarket H/U
This is that post
http://www.explorerforum.com/forums/showthread.php?t=212754
But what if you got a sup in the back or amp wear all you have to do is just unscrew it? When i got my first system it cost me about $750 for the amp and 2 sups someone broke my back window and pryed the sup out. I had it bolted down but they ripped the box off cut the wires and they run off, or the amp that is just screwed on with a Philips head. security screws and bolts. Since that day i just them in most of the stuff i use. Hear is a link to what i mean and wear you can buy them
http://www.brycefastener.com/
I will be doing a better wight up when i put my system in later but hear it is so far.
you will need:
bolts/nuts
# of security screw/big washers to hold up speaker to the box
8 big washers that the bolt head will not fit throw.
12 pack use as directed :p:
IF YOU MESS UP NOT MY FAULT THIS IS HOW I DID IT.
First you need to take the subs out of the box. Next find a good spot wear you can drill holes in the floor. Watch out for what you are drilling throw gas tank wires all that. I put my box in the back and went under the trunk and just drilled wear the box was that way all the holes line up. Next thread the bolt throw the holes and in the box. put on a washer and tighten the bolt up. The washer makes it harder for some one to just rip the bolt out, and for the extra $.12 and mint it takes you cant bet it. Then find the spot you want your amp to be. Drill holes for the bolts with a washer bolt it up and tightening. last put in ur sup as you would but with the security screws. keep the key in a safe place. and you all done.
easiest way to protect your stuff is not to advertise.
