Proving Oil Changes?
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
I usually start doing my oil changes myself when the warranty runs out, but my brother works in the service department at a Chevrolet dealership. I don't do them myself to save money because it cost me about $45 at the dealership and $30-35 at home. I do them myself because I like working on vehicles, I can locate other issues while doing routine maintenance, and I don't overtighten drain plugs and oil filters. I used to keep track of all maintenance, but since the invent of the oil life monitoring systems, I have let that slip. Light comes on, I change the oil.
The only car I owned that I didn't change the oil on was a Porsche 911, but that was because it was so low to the ground you couldn't get under it without it being up on a lift, and it held 15 quarts, and it had solid valve lifters that had to be adjusted about as often as an oil change.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
yup my buddy has a 84 Porsche 911 convert with a 3.4L 6 that is built up pretty gnarly, every oil change he takes it in. I was like dude "we got this", we fix and modify everything else.., he's like "no way, Ill take it to the shop" because they adjust the valves with every oil change and have to tune it twice a year for emissions testing....detune emissions then re tune........ I was like "let them do it"
Porsche is a big PITA but man that car sure can handle
Rick 2011 Explorer FROM DESERT FLOOR TO MOUNTAIN PEAKS, PROVING FORD EXPLORER CAPABILITY, Stock 2011 - 2019 Ford Explorer Discussion 4
Bobs2018Explorer How the OEM Oil Cooler works, on a 2018 with the 3.5 V6 Stock 2011 - 2019 Ford Explorer Discussion 3
P Oil leak help!! Stock 2011 - 2019 Ford Explorer Discussion 3
B Loss of power & Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 3
R Lab-Chemical Fee Charged for Oil Change Stock 2011 - 2019 Ford Explorer Discussion 11
M Oil vapor smell Stock 2011 - 2019 Ford Explorer Discussion 1
G Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
E 5w-30 oil in a 3.5 NA Engine Stock 2011 - 2019 Ford Explorer Discussion 6
B Oil leak Stock 2011 - 2019 Ford Explorer Discussion 6
S 3.5L Oil Pressure Sensor Location Stock 2011 - 2019 Ford Explorer Discussion 2
J Explorer 3.5 NA Oil Pan Removal and Install Information Stock 2011 - 2019 Ford Explorer Discussion 1
S 2018 leaking oil Stock 2011 - 2019 Ford Explorer Discussion 3
K 2014 Explorer Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
D 2017 Sport Possible oil leak? Should I be concerned? (pics) Stock 2011 - 2019 Ford Explorer Discussion 10
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
J 2018 Explorer Limited 3.5L oil leaks Stock 2011 - 2019 Ford Explorer Discussion 19
Jon M Using oil? Stock 2011 - 2019 Ford Explorer Discussion 7
R Oil Pump failure now have to replace engine Stock 2011 - 2019 Ford Explorer Discussion 22
C Oil leak leads to blown motor without warning Stock 2011 - 2019 Ford Explorer Discussion 45
O Does the 2013 Explorer Sport have a transfer case oil cooler? Stock 2011 - 2019 Ford Explorer Discussion 4
A Rear differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 10
Q Small Oil Leak - Passenger Side Stock 2011 - 2019 Ford Explorer Discussion 10
B Oil leak at start up in extreme cold. Stock 2011 - 2019 Ford Explorer Discussion 10
B oil line Stock 2011 - 2019 Ford Explorer Discussion 0
S ‘14 Explorer stalls in P with Low Engine Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 3
whitemage25 Low Oil Pressure warning at idle Stock 2011 - 2019 Ford Explorer Discussion 27
F 2011 Ford Explorer Low Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 5
E 2017 first PTU oil change and Mod Stock 2011 - 2019 Ford Explorer Discussion 7
C 2018 Explorer XLT Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 11
U Oil change in the wilderness Stock 2011 - 2019 Ford Explorer Discussion 27
D Oil press/Coolant temp/battery status? Stock 2011 - 2019 Ford Explorer Discussion 5
I 2017 Explorer sport, small oil leak, doesn't seem to get fixed. Stock 2011 - 2019 Ford Explorer Discussion 34
P 2013 Explorer oil leak Stock 2011 - 2019 Ford Explorer Discussion 2
N Engine Stall and Oil Pressure Warning While Parking Stock 2011 - 2019 Ford Explorer Discussion 5
O 2016 2.3L oil change too much oil? Stock 2011 - 2019 Ford Explorer Discussion 18
R First oil change for my explorer Stock 2011 - 2019 Ford Explorer Discussion 8
Eltee Resetting Oil Change Interval? Stock 2011 - 2019 Ford Explorer Discussion 7
Exit32 Factory oil filter dissection Stock 2011 - 2019 Ford Explorer Discussion 5
S motor oil debate. Stock 2011 - 2019 Ford Explorer Discussion 50
L 3.5L EcoBoost Turbo Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 13
H Rear Differential Oil Leak? - 2013 XLT 4WD 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
S Front differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 0
C 2011 explorer oil problem Stock 2011 - 2019 Ford Explorer Discussion 19
B Front Engine Cover Oil Leak on Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
G 2016 Explorer Sport Jerking/Stall Cabin oil smell Stock 2011 - 2019 Ford Explorer Discussion 2
L Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
rok8man 2017 Ford Explorer Massive Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport oil leak? Stock 2011 - 2019 Ford Explorer Discussion 10
K New Noise After Oil Change Stock 2011 - 2019 Ford Explorer Discussion 8
B 2017 Oil Pan leak Stock 2011 - 2019 Ford Explorer Discussion 34
Similar threads
