Lexingtonian
- February 2, 2017
- Lexington, KY
- 2016 Exp Sport w/401a
I Decided to tackle the PTU change on my 2016 XSport. My truck has 16,521 miles today. Got motivated around 9:30pm to do the job. Its now 2am as I type this. I went very slow and was deliberate about everything. Had several resets on the PTU vent hose routing. Tightening the hose clamp was a bit of a bear. Like an idiot I wasted 30 minutes and wicked hand cramps trying to tighten it with a straight blade screwdriver before I switched to a socket setup (DUH). I learned a few things and came up with a trick or two I hadn't seen yet. I'd like to thank this gent for putting up the YouTube Vid on how it looks in a '14 Police Interceptor.
A few things changed since the '14 and they are:
1. The Hex PTU Drain Plug is 1/4" (not 8mm or 3/8 drive) on 2016. This was HUGELY convenient for reasons you'll see in a bit.
2. The PTU Vent Hose has a different clip that you see in the Video Clip above for the '14. It pulls out easily. The hose looks shorter as well. It pulls off the PTU nipple very easy by the way.
3. The hose you should purchase is 5/16 i.d. Fuel Line (not the clear vinyl crap, get the good stuff) as pictured below. 2 feet is perfect, you'll end up trimming off approx 6 inches when complete.
A couple Photos of the OEM Piece next to the 5/16 fuel line.
This is approximately what is poking out when properly routed (of 2ft 5/16id fuel line)
To orient you here, on the bottom right of the photo is the top of the PTU and you can see the new PTU Vent hose (Fuel Line) hanging with the Hose Clamp. The top of the photo is the firewall shielding. I'm laying in a creeper nearly fully rolled under the truck (I'm 6' 2") looking up to get this view from behind the PTU. On top of the PTU you can see two aluminum coolant lines (think that's what they are) running parallel to one another. Behind that is where the nipple is. Taking the factory vent hose off, putting the new on one and tightening it down is a 100% blind operation. It can only be done from the ground working up. Don't even attempt it from the top on the explorer, there is no way to get to it. I tried. (trust me)
I managed to get a photo of the nipple you'll be installing the fuel line on. (it was tricky)
...Here's where about an hour of head scratching and thinkin' came to bear. I knew as soon as I pulled the plug the casted races on the PTU under the drain plug would fill and oil would find multiple pathways away to the ground. I really didn't want that. I filled the indented races with foam like you'd seal a window or door with and ensure it was in there pretty solid. You can see that pictured here.
Then I used duct tape to build a dam and predictable drain race for the oil once the plug came out. Next few photos is me building it. One of the O2 Sensors in the Cat is RIGHT FREAKING UNDER the drain plug, the photos do a poor job of demonstrating just how close and just how dead-nuts center that darn O2 Sensor is. I knew if I dropped the plug it'd end up all.over.my.exhaust. I just freaking didn't want the mess. Without further adieu... My solution..
