pulled codes. need info. | Ford Explorer - Ford Ranger Forums - Serious Explorations
92Explorer4.0
Reserve KS
92 4x4 eddie bauer
ok just went out and pulled codes. first set was 331 then 6 sec pause then i got 33. 33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE. i do have a 92 EB x 4x4. what should i do to try to fix this or should i worry about it. thanks
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
A '92 should be outputting 3 digit codes. Are you sure that wasn't 111 (111 repeat), 1, 111 (111 repeat)?
92Explorer4.0
Reserve KS
92 4x4 eddie bauer
idk for sure lol i dont have a CEL on just wanted to see if i could do it. i used a wire and turned the key on and it did fast and then slow codes.
92Explorer4.0
Reserve KS
92 4x4 eddie bauer
i did get 111 lol guess im good with codes nothen wrong with koeo.
walterd140
Ludlow, Massachusetts
'94 Sport
When you jump the wire & turn the key you will get the fast codes. You should get:
111
a second or two pause
111
a 6 second or so pause
now the real codes start. The 111 is a check (I believe) kind of telling you it is actually reading. You said you had no CEL, so these real codes are in the memory. You can clear them by leaving the key turned & pull your wire out.
Hope this helps. Try it again & see what you get
92Explorer4.0
Reserve KS
92 4x4 eddie bauer
after the code 111 i never got any codes after the long pause. i waited almost a minute after the last code read out. so now im gunna do a koer.
walterd140
'94 Sport
No codes is good. The koer is a bit more complicated. You need to do some brake stepping, then gear shifting. Better read up on it.
I tried it, but was not as successful as my Uncles code reader
DV8
Cedar Grove, WV
94 XLT
i thank my dad every day that i have to work on my 94 x. he has a snap-on diagnostic machine... so nice, so nice...
