Pulling motor out of 2000 mountaineer
D17Fetish
Mesa, AZ
2000 Mountaineer
im pulling the sohc motor out of my mountaineer and was wondering if i should take the engine harness out along with the valve covers nd coil pack..
all i have left to do is pull the last four bolts at the top that go to the bell housing.
i did look at the swedish how to thing but it doesnt help with those last few bolts
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
top bolts on bellhousing
I was able to remove several of the four top bolts by working thru the wheel wells after removing the inner fender flap. I only had to get under the vehicle for one of the four and needed several drive extensions to loosen it. I loosened all eight bolts first, then removed the top four bolts, supported the engine weight with a crane and the transmission weight with a scissor jack on top of a block of concrete as shown in this thread: Transmission jack Only then did I remove the lower four transmission to engine bolts. I disconnected the main engine wiring harness from the PCM, the firewall (ground) and connector on the driver side.
