Question about 99 Ranger Transmission | Ford Explorer Forums
daydk1
Estill Springs, TN
1999 Ranger XLT 4x4
I have a 1999 Ford Ranger XLT 4X4 with 3.0 engine, automatic transmission. My transmission had gone bad, so I bought a used 1999 Ranger automatic transmission with only 46,000 miles on it. I hired an auto mechanic to swap out my old one with the new one, including the torque converter that came with the new one.
The question I have is this...It seems the power is gone that I once had. I really notice it when I'm towing my 6x8 foot trailer with a mower on it. The RPM's seem to stay really high just to travel at 65 to 70 mph. I've also noticed it when I'm not pulling anything and I'm traveling along at 55 mph and I go to pass someone on a two lane road. It shifts into passing gear fine, but it just seems like it takes longer to get up to speed to make the pass. Any ideas on what might make it seem to be not as powerful?
P.S. The transmission shifts fine and operates as it should. It just seems the power is gone from the truck that I once had.
You have to determine if it's engine or transmission related. Is the pressure on the transmission low? How is the compression of the engine? What are your maximum RPMs? Did you check the fuel pressure or replace the fuel filter? When was the last time everything was tuned up?
I would assume it's transmission related. The old transmission was fine once I got out of 1st. I've noticed the power is not there on this transmission when it's under a load. How do I check the pressure on the transmission?
