russell bruesch
- January 25, 2011
- Location
- new buffalo michigan
- 2017 limited explorer
The manual; shows a single filament bulb 2005-Hb3 for the headlamp. A 2005 bulb is catagorized as a high beam bulb correct? How does this bulb give off low beam lighting? When activating the low beams it sounds like some motorized shield comes down to cutoff the upper part of the lamp to direct the light down,is this correct?
This seems like an unconventional system where as most headlight systems use either seperate bulbs for high/low beams or dual filament lamps. Are the stock halogen lenses reflector or projecter? They look like projector lenses to me.
