Question about possible fuel pressure issue.
Kobalt
South Carolina
2002 Explorer
Hello all!
To start out, my 2002 XLT's fuel gauge had not worked for years. And occasionally it would have some trouble starting. It would try to turn over but would not start until after about three tries. But that was rare.
So I changed the fuel pump and sending unit. My gas gauge works and reads correctly most of the time. Although sometimes it says that I have more gas than I really do. I can handle that for now, but ever since we changed the fuel pump and sending unit, you have to try to turn the engine over about 3 or 4 times before it will start. Or you can turn the ignition key to on and turn it off about three times to prime the fuel pump to get it to start.
So I think I know that problem, but I am clueless on what to do to fix it. It is a fuel pressure issue and how would I go about fixing it. Any help would be appreciated. Thank yall so much!
sgully67
Toms River, NJ
2004 Ford Explorer
The fuel pump/sender module you put in is most likely defective. There is a check valve in the unit that is supposed to maintain a certain amount of pressure in the system when the engine is shut down. If the check valve is not working it allows all the fuel to drain back into the tank.
L Carfax question on a possible new purchase Stock 2002 - 2005 Explorers 3
S 2002 Explorer Coolant question Stock 2002 - 2005 Explorers 1
I Radiator Question Stock 2002 - 2005 Explorers 10
M quick question, is the front diff LS or open? Stock 2002 - 2005 Explorers 7
M front and rear wheel bearings question Stock 2002 - 2005 Explorers 3
S Hello and a question. Stock 2002 - 2005 Explorers 2
A Transmission question Stock 2002 - 2005 Explorers 2
B Ffv question Stock 2002 - 2005 Explorers 0
P 4 wheel Drive Question Stock 2002 - 2005 Explorers 2
M Question about reverse sensor codes... Stock 2002 - 2005 Explorers 1
A 2005 Explorer V6 4.0 Timing Chain Question Stock 2002 - 2005 Explorers 2
G 2003 4.0L timing chain balance shaft question Stock 2002 - 2005 Explorers 6
F Overheating Question? Stock 2002 - 2005 Explorers 12
J Window Switch question Stock 2002 - 2005 Explorers 0
J Tricky Front End Heat Question Stock 2002 - 2005 Explorers 6
S Exhaust manifold question Stock 2002 - 2005 Explorers 3
D Towing Question Stock 2002 - 2005 Explorers 5
A Question about uneven tire wear Stock 2002 - 2005 Explorers 4
D ABS Wheel sensors question Stock 2002 - 2005 Explorers 1
A AC question Stock 2002 - 2005 Explorers 7
B Sand Driving - Quick Question Stock 2002 - 2005 Explorers 5
D Coolant hose part question Stock 2002 - 2005 Explorers 0
M Aviator vs Explorer seat question Stock 2002 - 2005 Explorers 2
H Installing timing chain tensioners- question - extra part? Stock 2002 - 2005 Explorers 0
M 02 Eddie Bauer dreaded transmission question Stock 2002 - 2005 Explorers 3
J Rear end swap question. Roll controll Stock 2002 - 2005 Explorers 5
I 02 engine hesitation question Stock 2002 - 2005 Explorers 3
9 4.0 Sohc compatibility question Stock 2002 - 2005 Explorers 1
S Exhaust system question Stock 2002 - 2005 Explorers 2
J Question about heater actuator 2005 Explorer Stock 2002 - 2005 Explorers 3
A A/C issue question. Drivers vents warmer...FIX = ADD FREON Stock 2002 - 2005 Explorers 1
D Maybe a stupid question Stock 2002 - 2005 Explorers 3
D Buying a 2003 question Stock 2002 - 2005 Explorers 5
W Question about gear selector 2005 EB 4.6L 4WD Stock 2002 - 2005 Explorers 1
J 05 explorer sly reverse sensor question Stock 2002 - 2005 Explorers 2
T Transmission swap torque converter question 05 explorer Stock 2002 - 2005 Explorers 6
R Remote Entry Question... Stock 2002 - 2005 Explorers 7
V Question abou P0304 and breaking plugs Stock 2002 - 2005 Explorers 1
P code p1131 & p1151 check engine question Stock 2002 - 2005 Explorers 2
X Simple v8 question Stock 2002 - 2005 Explorers 4
mgmgmg Keyless Entry Question? Stock 2002 - 2005 Explorers 2
J General 4.0 Maintenance Question Stock 2002 - 2005 Explorers 2
A Rear Door Lock Question...not sure if its an issue. Stock 2002 - 2005 Explorers 3
B $200 2004 Mountaineer Question Stock 2002 - 2005 Explorers 3
J Quick Timing Chain Question Stock 2002 - 2005 Explorers 4
M 4.0L Alternator Question Stock 2002 - 2005 Explorers 14
C 2002 Transmission question Stock 2002 - 2005 Explorers 14
C 2003 Ford Explorer Question's on fluids Stock 2002 - 2005 Explorers 37
Z Charging question Stock 2002 - 2005 Explorers 24
P Question about sway bar end link lengths; experiences with 1AAuto Stock 2002 - 2005 Explorers 10
Similar threads
