Dash Riprock
- April 9, 2005
- LA, CA
- 95 Explorer XLT
95 XLT 4.0 OHV
The CEL came on recently with no change in performance or drivability.
Checked codes and got:
KOEO: 337
KOER: 337
CM: 337, 122
The 122 is a TPS low code, one that I have had in the past (http://www.explorerforum.com/forums/showthread.php?t=159369).
337
(O,R,M)
EGR feedback signal is/was was high - EVR
This past weekend I did the much debated TPS voltage adjustment, initially found it to be .90 vdc, and adjusted TPS to read .98 vdc. After disconnecting battery and driving, the CEL relit, with the 337 code repeating in KOEO, KOER, and CM, but the 122 code gone. (Somehow I doubt this was the source of the 122 code, we'll see)
My DPFE was replaced last July.
So, what does a code 337 ask me to do? Is there a standard procedure to fix this? Simply replace EGR valve after checking wiring?
My wife actually took this for her smog check while the CEL light was on and it passed.
Hints and suggestions welcomed. Thanks
KOEO: 337
KOER: 337
CM: 337, 122
337
(O,R,M)
