surf
- September 17, 2003
- Atlanta, GA
- '93 XLT
I am getting ready to install the temp sending unit but had two questions. The Haynes manual says you need to partially drain the cooling system before removing the sending unit and then you need to put Teflon tape on the threads before installing the new unit. Is it really necessary to drain the coolant? I have read that if you apply any sealant to the threads it needs to be electrically conductive and teflon tape is not electrically conductive. Any help is greatly appreciated.
