NickEx623
- June 14, 2020
- Maryland
- 1992 Ex Eddie Bauer
Hi all! Bought a 92 Explorer 4wd a month ago to wrench on. Plans are to make it a fun/reliable truck for light off roading/getting groceries. I have some questions/seeking advice before starting the build, here it is!
1. Plan on putting an 8.8 rear axle from an later year Ex and jamming in 4.88 gears and reap the benefits of disc brakes since will be doing a 4" lift and run 35's. I assume the rear should be a simple bolt on replacement, correct? Stock 92 Ex driveshaft?
2. How much work will I have to do to the exisiting brake lines/system to accomodate the disc brake calipers or is it just a matter of swapping/fitting hoses? Also, I plan on doing the front brakes upgrade with Ranger knuckle/caliper for bigger calipers, will my stock booster/master cylinder be fine with the ranger calipers and the rear calipers on the 8.8?
3. Considering the amount of work I plan on doing on the truck, I figure I may as well rebuild the engine while I'm at it. Where can I find a parts list/guide to rebuilding the OHV and giving it a bit more power? Would like to stick in 410 or 422 cam and probably port it but not sure what else I should do.
4. Any dudes on this forum who can build a bada** tubular front/rear bumper? Don't want to pay $1250 each, which is what some companies are asking
