donaldthacker
- October 4, 2004
- va
- 99, sport w/35" MTZ's
how does the transfer case effect reverse? I have heard the transfer case being bad when reverse goes out
also i checked the travel on the reverse servo piston. When I gently place a long screwdriver into the piston rod hole it actually took more screwdriver length to touch the band than the piston rod currently has. The rod itself does not appear to be broken, but I do not know what the original length is.
I do have manual first so I am a bit confused by this since I am not a transmission guy
